Print at Sep 24, 2026, 4:37:12 PM
Posted by Ceciliabr at Feb 4, 2019, 11:19:03 PM
Re: Various issue with walls/textures
If it would be only 1 or 2 times, ok, but more than 30 times is too much.
Make a group, or better yet: Create a 3D OBJ file, a customized window including your make-up boxes. Then copy/paste.
Ceciliabr, how should a box which has 90° angles help to build the steps of my stairs which do not have a rectangular shape?
Just like in real life, you build your model with bricks or tiles.
Here I have used 20x20 cm boxes to create a simplified construction:
You can of course alter the size of your building blocks, and you can also use textured triangles and cylinders in addition to the boxes. The reason I go for boxes is that I find mimicking real life to be a good starting point when making 3D models wink
If you export your construction to an OBJ-file, you can easily change and customize textures to fit the model after importing it to your project.
Making this simple demo took me some ten minutes.
A more complex construction will naturally take a bit longer.
