Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Various issue with walls/textures » » » » Post: Re: Various issue with walls/textures |
Print at Sep 24, 2026, 3:08:41 PM |
| Posted by thoron at Feb 5, 2019, 4:15:21 PM |
Re: Various issue with walls/textures Hello Ceciliabr, Now I got it, very tricky I played a little bit with your model with regard to customizing textures and additional questions came up. Hope you can answer them: 1. case: Loading your model, marking all boxes and change texture of the selection (not with the material change panel as being inactive) and got this. Again some areas of distortion: 2. Case following your advice exporting you model as obj-file and importing it again. Using texture change (not the material change panel) and got this. Other areas of distortion: 3. case Doing the same as in case 2, but now using the material change panel and assigning each of the 6 areas the same texture. Result is strange again, because the scaling of the texture was changed (to very small). You see as well a simple wall with the same texture and 100% scaling. ![]() I find this very strange and I don't get the logic behind. Maybe you can shed some light on this. Many thanks. |
Current timezone is GMT Sep 24, 2026, 3:08:41 PM |
