Print at Oct 2, 2026, 9:23:08 PM
Posted by Puybaret at Feb 18, 2019, 10:24:48 AM
Re: Changing defaults
These settings could be changed in a customized version of Sweet Home 3D. Changing some default settings doesn't require high level programming skills most of the time (for example, hiding areas of new rooms just requires to replace true by false in Room.java), but still, you would still have to build the program...
If your request is rather a suggestion of new preferences that would let the end user choose some settings, I'm not sure it's worth overloading preferences panel with all kinds of stuff.
