Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Basement is not at set negative level » » » » Post: Re: Basement is not at set negative level |
Print at Sep 24, 2026, 5:06:57 AM |
| Posted by dorin at Feb 25, 2019, 6:39:41 AM |
Re: Basement is not at set negative level Surround Your pit with walls. As I see You have a room without walls. If You don't want to reinforce the pit than use an invisible box to make a hole in the ground (eventually imported as staircase). ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 24, 2026, 5:06:57 AM |
