Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Lighting problem with sloped ground » » » » Post: Lighting problem with sloped ground |
Print at Oct 5, 2026, 9:18:54 AM |
| Posted by TinkyWinky at Mar 1, 2019, 10:43:01 PM |
Lighting problem with sloped ground I experience a problem with the sun light which I do not quite understand, maybe somebody here can help: Very very slight sloped grounds reflect too few sun light when comparing to flat grounds. In this image: there is a very very dark grass patch at the far end to the right at the hedge. This is much darker than expected. The slope has an angle of 1.77° and goes down to the right. To compare a non-sloped flat ground, see the rectangular strip which extends from the resting young people to the hedge. To the left of this strip, we have a similar slope into the other direction. The photo was rendered at 13:30h in summer. I was expecting the amount of reflected light to depend on the scalar product of surface normal vector and light direction, but what I see here is odd. What's happening here? Why affects a slight variance the object's brightness so much? It's not a texture problem, solid green color (matt surface) shows the same strange result. |
Current timezone is GMT Oct 5, 2026, 9:18:54 AM |
