Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Group of objects » » » » Post: Re: Group of objects |
Print at Sep 27, 2026, 2:28:15 AM |
| Posted by Puybaret at Sep 28, 2009, 2:43:38 PM |
Re: Group of objects Grouping/ungrouping a set of objects should be available in the coming versions to help you move, resize and rotate a group of objects. Meanwhile, here are two workarounds: - you may select the objects you want to elevate and choose Furniture > Modify... menu item to change their elevation, but then, of course, all the selected objects will have the same elevation, - you may select these objects, copy paste them in a new home, export that document to OBJ format with 3D view > Export to OBJ format... menu item, import the exported OBJ file with Furniture > Import furniture... menu item, and move the imported group of objects. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 27, 2026, 2:28:15 AM |
