Print at Sep 24, 2026, 2:16:46 PM
Posted by hansmex at Mar 3, 2019, 7:05:18 PM
Re: New to Sweet Home 3D
INTRO
Trogladyte
a red neck and/or crack snorting alcoholic who spends most of their time in WalMart buying discount paper towels and eating at the ketchup packets at the McDonalds in the store.
they usually drive an astro van packed with six of their illegitamate love children, none of which wear pants or shoes.
Source: Urban Dictionary
Troglodyte
Troglodyte is a human cave dweller, from the Greek trogle "hole, mouse-hole" and dyein "go in, dive in".
...may also refer to:
1 - Historiography
Troglodytae or Troglodyti, an ancient group of people from the African Red Sea coast
2 - Science
Homo troglodytes, an invalid taxon coined by Carl Linnaeus to refer to a legendary creature
Pan troglodytes, the common chimpanzee
Troglodytes (bird), a genus of small bird
3 - Arts and fiction
etc etc
From Wikipedia, the free encyclopedia
ANSWER(S)
0 - Don't compare SH3D with $1000 professional CAD software. It's not CAD software, not intended to be, nor claiming to be. It has clear limitations when used for architectural design (no elevations, no cross-sections).
1 - Exact wall length: click for the first point, then on the keyboard hit ENTER, in the pop-up window you can enter exact length, angle and thickness.
2 - Dim1 - Don't measure the corner, measure the wall? Maybe more explanation is needed...
3 - Dim2 - No
4 - Dim3 - No, dimensions do not auto-update
5+6 - Learn to use the program? The program uses "magnetism" which gives visual clues as to what will happen when you click. You may need to learn what to watch out for. There's several types of cross-hairs and extension lines that indicate that you can connect two wall sections, eliminating the need for time consuming clean-up afterwards.
