Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Select Hide Utility plug-in » » » » Post: Select Hide Utility plug-in |
Print at Sep 23, 2026, 3:55:54 PM |
| Posted by dorin at Mar 5, 2019, 8:40:47 AM |
Select Hide Utility plug-in I've start learning java two month ago and this is my first script with 90% of my contribution, so don't expect too much. After install You will find an entry under Menu Edit->Select special... This plug-in let You to: - make complex selection at current level and then copy/delete/paste or - hide selected and so on. Hope the interface are self explained. PROBLEMS: 1. Conflict with Utility2Plugin; can't coexist so chose one. 2. I've don't know (yet) how to implement correctly the UNDO-REDO action. In this version, undo (only for hide/show section) work acceptable BUT redo didn't! 3. That's being said I recommend to test on an test-file or backup. The plug-in with sources and licence GPL included could be find here Select Hide Plugin or at Source Forge ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 23, 2026, 3:55:54 PM |
