Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Virtual visit in Ubuntu 18.04 » » » » Post: Re: Virtual visit in Ubuntu 18.04 |
Print at Oct 16, 2026, 5:53:55 AM |
| Posted by Jonnie63 at Mar 31, 2019, 1:36:40 PM |
Re: Virtual visit in Ubuntu 18.04 @mrwolfe I am running the same version of Ubuntu as you ( 18.04 LTS ). I can confirm the behaviour you describe. Perhaps another route may suit you. I have a large flat screen TV with HDMI on both TV and laptop I view the virtual visit on the TV and the plan view on my laptop ( after first separating the virtual view so that it appears in a new window ) So yes it does not seem to work with workspaces on the default monitor ( workspace UP or Down etc ). But it works fine with a second monitor ( workspace Left or Right ). I did find some idiosyncrasies. SweetHome 3D gives an error report telling me update drivers if and only if I try to import new furniture whilst the virtual visit is on the TV monitor - as long as I always move the virtual visit to the laptop top monitor before importing new furniture it works fine. I suspect my laptop drivers are not quite set up correctly for second screen but the point is that it works at a practical level as long as I do not mind moving all windows to the laptop workspace before I perform import furniture operations. Once in a while I forget and Sweethome exits with an error message and I just have to restart - could be a pain if I did not save regularly but so far no real problem. The other anomaly I encounter is that my system would only work reliably if I set the TV to be right of the laptop screen rather than left of it - this is a setting that defines which boundary left or right you should slide a window for it to move into the other window. I cannot remember the consequence whether SweetHome crashed or exited. In many ways you can solve this just by the way you position your large screen - it just helps intuitively if a left screen slide ( from laptop to large screen ) corresponds with the large screen being physically a little more to the left of your laptop screen - a bigger desk or desk reshuffle can solve the problem at a non software level. If this sounds like a lot of hassle it isnt really - I am designing 3 buildings so many many hours involved and only say 1 hour messing around to get to grips with the anomalies and devise a working style to get around it. I would advise anyone with a really large TV screen and suitable HDMI connections to try 3d virtual visit on a really large screen, it so much improves the whole experience and helps you feel as if you are there in person. I rate this as the single biggest improvement in my working setup in terms of being able to get a feel for the environment I am designing - I could not rate it highly enough. |
Current timezone is GMT Oct 16, 2026, 5:53:55 AM |
