Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Guide To Creating A Flat Roof With Cut Outs For Skylights » » » » Post: Re: Guide To Creating A Flat Roof With Cut Outs For Skylights |
Print at Oct 4, 2026, 3:39:30 PM |
| Posted by Jonnie63 at Apr 15, 2019, 7:39:11 PM |
Re: Guide To Creating A Flat Roof With Cut Outs For Skylights Advantages To This Method. 1. The perimeter of the roof can be edited without needing to adjust the Skylight unless the roof edits actually affect the skylight area. 2. If the roof is slid around it can be seen that the skylight stays where it is. Alternatively if the roof, Skylight and Skylight liner are all selected then they can be moved as a group. 3. To change the cut dimensions of the Skylight it is only necessary to edit the Skylight tool - however the Skylight liner will not automatically resize because it has no real connection with either the Skylight hole or the Skylight tool that made it - it was created and sized purely by eye judgement so it will need similar attention again. Seriously though its not as complex as it sounds and was exactly the solution I was looking for. I can now create and tweak roofs and skylights but I will not have to "start all over again" each time I make a change to my house that affects the walls or roof. ===================== END ================================ |
Current timezone is GMT Oct 4, 2026, 3:39:30 PM |
