Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Guide To Creating A Flat Roof With Cut Outs For Skylights » » » » Post: Re: Guide To Creating A Flat Roof With Cut Outs For Skylights |
Print at Oct 4, 2026, 8:35:18 PM |
| Posted by Jonnie63 at Apr 16, 2019, 9:50:38 AM |
Re: Guide To Creating A Flat Roof With Cut Outs For Skylights Hi Mike, Thanks, yes it looks like its pretty much the same thing, the article is even in the Tips and Tricks section where I looked! I guess I did not pick up on it because it only mentioned walls in the title, I did pick up on the later "How To Design A Sloping Ceiling With A Window" I have been aware of that one but it wasn't really what I needed. I will look at your suggestion for the "liner" not quite sure what the "check the box for the stairs" bit means - if that will somehow autosize the hatch then it would probably be less work. Somehow I don't feel it was a waste of time, good learning experience and now I have entered the world of levels which I think will give benefits. I instinctively like the idea of being able to group and organise all the roof stuff in different levels representing different heights, it might be worth checking to see if there are any issues having an additional ground zero level just for the invisible cut out boxes just to keep it tidy. Yes thanks to Veronique, good article probably more coherent than my attempt as well. I do wonder however if it is possible to edit the Blog whether it might prove useful to add something to the title to include roof as well as walls. |
Current timezone is GMT Oct 4, 2026, 8:35:18 PM |
