Print at Sep 30, 2026, 6:20:33 PM
Posted by hansmex at Apr 30, 2019, 4:53:04 PM
Re: Cut-out for kitchen sink
1 - Start a new drawing, add a level with elevation 86 cms and floor thickness 4 cm;
2 - On this level draw a room that represents the shape of your counter top; forget about the sink - add colour or texture;
3 - Import a sink and mark it as "staircase";
4 - At the lower level insert your sink - give it the correct elevation so that the top of the sink is flush with the counter top;
5 - At the top level select sink and counter top; export as OBJ (selection only) and re-import it.
6 - It works for me, so should work for you.
Note: (1) assumes that the surface of your counter top is 90 cms above the floor, and that your counter top is 4 cms thick. Adjust to your needs.
