Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Multi-connected walls » » » » Post: Re: Multi-connected walls |
Print at Oct 10, 2026, 8:26:07 AM |
| Posted by Puybaret at Oct 26, 2009, 9:20:05 AM |
Re: Multi-connected walls I think you're on the good way. The hardest problems to solve are: - the management of undo/redo but adapting PlanController.JoinedWall class shouldn't be so difficult, - how should walls corner points should be computed in Wall#getPoints method when their start or end point is connected to more than one wall (by the way, you'll see that most getPoints invokers expect 4 points so I wouldn't change that if you don't want to program too much things). Please keep us informed about your program. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 10, 2026, 8:26:07 AM |
