Print at Sep 28, 2026, 1:17:29 PM
Posted by Puybaret at Oct 27, 2009, 10:20:52 AM
Re: Problem with "Create photo function"/Internal Renderer
Instead of entering directly "java", you have to write the full path of "java".
It will probably be:
C:\Program Files\Java\jre6\bin\java.exe
Then the command will become:
"C:\Program Files\Java\jre6\bin\java.exe" -Xmx1024m -jar path/to/SweetHome3D-x.y.jar
There's an other solution, create a text file named SweetHome3D.l4j.ini in the same directory as SweetHome3D.exe, and write the following text in that file:
-Xmx1024m
and relaunch Sweet Home 3D.
