Print at Aug 9, 2026, 11:25:12 AM
Posted by Puybaret at May 14, 2019, 9:30:32 AM
Re: Export to HTML5 plug-in
The JavaScript code of the viewer releases available in the https://sourceforge.net/projects/sweethome3d/files/SweetHome3D-viewer/ folder is minified, so hardly readable and modifiable.
The readable source code is available in the sibling folder https://sourceforge.net/projects/sweethome3d/files/SweetHome3DJS-source/
If you want to modify it, be sure to read the README.TXT file included in the source code to install the required tools. The default Ant target of the project will generate a new version with updated minified code.
