Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How cam i do pipes or hydraulic connections? » » » » Post: Re: How cam i do pipes or hydraulic connections? |
Print at Sep 25, 2026, 6:54:08 PM |
| Posted by ottertooth at May 26, 2019, 10:44:12 PM |
Re: How cam i do pipes or hydraulic connections? Select each item individually, export it and import it, if you put a check mark in the box to add to library you should be able to get all four How do you do that? Nothing I'm doing works. I clicked on the pipes_plumbing.sh3d link again. It says "You have already downloaded this." So I look in the folder where it's downloaded. I'm not seeing any option to choose the other 3 pipes individually. There's just the file I already downloaded and imported, and I only get one pipe out of that. I can see all 4 pipes in the Sweet Home 3d window that opens up, but there does not appear to be any way to install the other 3 pipes into the actual program. I don't see any 'export' option other than 'export to OBJ format' and 'export to SVG format. Is that it? Not sure what those do. When I attempt those, it says "the format of the chosen model isn't supported. Please choose another model." Clicking on one of them and choosing 'import background image' doesn't work. I don't see anything that allows me to import the 3 other pipes. |
Current timezone is GMT Sep 25, 2026, 6:54:08 PM |
