Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Additional Sunflow options (tests) » » » » Post: Re: Additional Sunflow options (tests) |
Print at Oct 2, 2026, 11:15:12 PM |
| Posted by enkonyito at Jun 5, 2019, 12:01:32 AM |
Re: Additional Sunflow options (tests) * Options: -quick_uvs : Renders the UVs of objects. -quick_normals : Renders the normals of objects. -quick_id : Renders using a unique color for each instance. -quick_prims : Renders using a unique color for each primitive. -quick_gray : Renders all the objects in the scene gray diffuse, overriding all shaders. -quick_wire : Renders objects as wireframe. -quick_ambocc X : Renders a scene in ambient occlusion mode with a certain distance (X). Only one override shader at a time can be used. SH3D implementation: String shaderOverride = null; // "show_uvs","show_normals","show_instance_id","show_primitive_id","quick_gray","wireframe","ambient_occlusion" if (shaderOverride.equals("ambient_occlusion")) { float maxDist = 200f; this.sunflow.parameter("maxdist", maxDist); } this.sunflow.shader("cmdline_override", shaderOverride); this.sunflow.parameter("override.shader", "cmdline_override"); this.sunflow.options(SunflowAPI.DEFAULT_OPTIONS); shaderOverride != null ---------------------------------------- EnkoNyito |
Current timezone is GMT Oct 2, 2026, 11:15:12 PM |
