Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Multiple paste & Distribute elevation plug-in » » » » Post: Multiple paste & Distribute elevation plug-in |
Print at Oct 2, 2026, 4:52:05 AM |
| Posted by dorin at Jun 9, 2019, 10:18:37 AM |
Multiple paste & Distribute elevation plug-in Finally I reach the target for what I've start learning java. Maybe is time to start to forget, to make room for other knowledge. This plug-in add two necessary (IMHO) tools: 1. Multiple paste (under Edit->Paste special...) 2. Distribute elevation (under Furniture->Distribute elevation) While SH3D is a 3D software I think is must to have a complete set of tools including for manipulation in 3D. Anyway I don't intend to spend time to write an user manual for this; Nobody read it! So: risk, try, fail, observe & learn and try again. You could find the plug-in here Paste special & Distribute elevation or on Source Forge. Few screen shoot: Insert objects in plan then select and copy (Ctrl+C) the desired object(s) then deselect them ![]() Edit->Paste special... and insert values ![]() This could be the results for different values and objects ![]() Example of use distribute elevation to make stairs Elevate one step to maximum necessary; select all steps and... ![]() This could be the result ![]() Of course I know someone for who will don't work but I can't help him ![]() PS: This plug-in is a little late for VeroniQ but could be useful for future tutorials. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Oct 2, 2026, 4:52:05 AM |
