Print at Oct 2, 2026, 9:51:34 AM
Posted by hansmex at Jun 9, 2019, 10:54:05 AM
Re: objects with texture from a picture
My guess is that you want to know how and/or why a texture repeats itself on a model??
When you import a texture you are asked to indicate the size of the texture in centimeters (cms) or feet-inches.
Imagine the following situation:
- you import a texture 250 pixels wide and 500 pixels high.
- you want to apply this texture exactly ONE time on a model (door?) sized 100 cms wide and 200 cms high.
When during importation you are asked to indicate the size of the texture, you should give 100 centimeters as the width of the texture (or 200 cms as its height). Now the texture will fit perfectly on your model.
Any other size will make the texture repeat (if smaller) or show only partially (when bigger).
