Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Multiple paste & Distribute elevation plug-in » » » » Post: Re: Multiple paste & Distribute elevation plug-in |
Print at Oct 2, 2026, 5:32:04 AM |
| Posted by hansmex at Jun 9, 2019, 1:12:33 PM |
Re: Multiple paste & Distribute elevation plug-in Dorin, Thanks for this useful plug-in. I tested it and found the following problems: 1 - I open a new instance of SH3D without any furniture. 2 - I insert one (1) model and select that model. I then look at Edit -> Paste Special, but that option is still gray and cannot be used. I have to select that model and copy-paste it, before I can use Paste Special. When the copy of that model is selected and I use Paste Special, the plug-in copies the first instance of the model, not the second one that is selected. 3 - When (after step #2 above) I insert a second model and I try to copy that model, the plug-in copies the first model, not the second. As an extra feature, it would be very nice if you could add Rotate to your plug-in. That would make it possible to make a spiral staircase (and many other things). I'm using Windows 10 64 bit and SH3D v6.1.2 I hope this helps you. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Oct 2, 2026, 5:32:04 AM |
