Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Problem with "Create photo function"/Internal Renderer » » » » Post: Re: Problem with "Create photo function"/Internal Renderer |
Print at Sep 27, 2026, 5:25:26 AM |
| Posted by carolaclavo at Nov 6, 2009, 3:05:00 PM |
Re: Problem with "Create photo function"/Internal Renderer Instead of entering directly "java", you have to write the full path of "java". It will probably be: C:\Program Files\Java\jre6\bin\java.exeThen the command will become: "C:\Program Files\Java\jre6\bin\java.exe" -Xmx1024m -jar path/to/SweetHome3D-x.y.jarThere's an other solution, create a text file named SweetHome3D.l4j.ini in the same directory as SweetHome3D.exe, and write the following text in that file: -Xmx1024mand relaunch Sweet Home 3D. Is there anything like this I can do on the Mac version? I'm not able to save a photo in high quality. Thank you :) |
Current timezone is GMT Sep 27, 2026, 5:25:26 AM |
