Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Create furniture by polilne contour extrusion? » » » » Post: Re: Create furniture by polilne contour extrusion? |
Print at Oct 2, 2026, 2:58:40 PM |
| Posted by Puybaret at Jul 24, 2019, 7:13:01 PM |
Re: Create furniture by polilne contour extrusion? A room is already double-sided if it belongs to a level with an elevation > 0. As in the attached example, you could: - create a new level - draw your shape with walls in the elevated level - add a room that will cover the entire surface of the walls by double-clicking on the walls instead of double-clicking inside the walls - copy the room - add a new level - paste the copied room and hide its ceiling - choose Edit > Select all at all levels menu item - finally, export the selection at OBJ format or use CopyAsNewFurniture plugin Et voilĂ ! A star is born ![]() ---------------------------------------- ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 2, 2026, 2:58:40 PM |
