Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Create furniture by polilne contour extrusion? » » » » Post: Re: Create furniture by polilne contour extrusion? |
Print at Sep 30, 2026, 5:44:24 PM |
| Posted by Gildaniel at Jul 26, 2019, 1:56:56 PM |
Re: Create furniture by polilne contour extrusion? The easiest method is to simply draw a room in an elevated level, then export the room. How could I forget it, as I even used this method in the past? Thank you, this is exactly what I was looking for! The one nuance with CopyAsNewFurniture method - menu option not active with only room selected, so I add to selection any empty object (opening), now it is possible to use this feature. Also after experiments I discover that floor thikness of this special level should be not less then it's elevation to get correct piece without "air" beneath Yours, Daniel |
Current timezone is GMT Sep 30, 2026, 5:44:24 PM |
