Print at Oct 2, 2026, 8:39:12 PM
Posted by enkonyito at Aug 9, 2019, 2:08:54 AM
Re: Additional Sunflow options (tests)
@Ceciliabr
It's like shininess is either on or off, with nothing in between.
In the Modify furniture panel, Matt=0 and Shiny=0.5.
In the Furniture materials panel, Matt=0 and Shiny=1. The Java 3D preview lets you see the difference in shininess.
When rendering, Sunflow applies a shader to the material that "changes" the shininess. (see pages 14 to 23 of Sunflow Wiki PDF)
Is this just a result of the limitations imposed by SH3D, or is this a real Sunflow limitation?
As Puybaret had told me : "There's no limitation".
Sunflow's standard configuration in Sweet Home 3D is based on several tests performed in 2010 (Test 1, Test 2).
Enko
EnkoNyito
