Print at Oct 1, 2026, 4:04:51 AM
Posted by hudtwalcker at Aug 12, 2019, 5:27:58 AM
Re: Issue with Imported furniture gone from library after use HELP !! PLEASE !!
As long as they are in your project you can still get them into your library, export them, 1 at a time, import it, during the import process make sure the box is checked to add to library, name the object, choose a folder to add it to, existing or create 1, i save mine to a folder called "mine", original eh. All this is done very simply during the import process.
There is also a "copy as new furniture" tool,never figured what that does.
Sorry, one dumb question, how do I export furniture ? Do I select it on the list (bottom left) and export it as CVS format or do I select something that is on the floor plan and export it as SVG Format ?
