Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Livingroom in new apartment » » » » Post: Re: Livingroom in new apartment |
Print at Sep 25, 2026, 8:59:11 AM |
| Posted by Bartosz at Oct 11, 2019, 6:15:58 PM |
Re: Livingroom in new apartment Good job. I especially like the models, however VeroniQ made a good point, I also noticed sun leaks. I recommend to re-doble click all your floor corners to make them match wall corners or even overlap them, then your celiling will be sealed as well. I had the same bad experience - when your main plan is not locked then it's very easy to accidently move the floor when working on models. I appreciate your work on lighting. Can you make some other angles? |
Current timezone is GMT Sep 25, 2026, 8:59:11 AM |
