Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Two level with the same elevation: some rooms on upper level are transparent » » » » Post: Re: Two level with the same elevation: some rooms on upper level are transparent |
Print at Sep 29, 2026, 5:51:01 AM |
| Posted by Gildaniel at Oct 15, 2019, 3:42:51 PM |
Re: Two level with the same elevation: some rooms on upper level are transparent Without downloading your file i can suggest: either draw "grass" room AROUND the house (NOT UNDER it), or raise the house level a little bit so it's no longer at the same elevation as grass level. Usually I use sattelite or cadastre map to find needed land area, screenshot and import this picture as a background image, scale it to real dimension and draw "grassed" room over it, to discuss where to place building, moving it around. It's possible to draw room around house, as a last resort, thank you. If house elevation will be hier then ground level, no grass will be seen on the plan at all. |
Current timezone is GMT Sep 29, 2026, 5:51:01 AM |
