Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Two level with the same elevation: some rooms on upper level are transparent » » » » Post: Re: Two level with the same elevation: some rooms on upper level are transparent |
Print at Sep 30, 2026, 6:20:50 PM |
| Posted by Gildaniel at Oct 15, 2019, 4:22:53 PM |
Re: Two level with the same elevation: some rooms on upper level are transparent I found some regularity in this bug. If you draw room in closed wall area - it is transparent. If you draw in non-closed area - it normal ![]() |
Current timezone is GMT Sep 30, 2026, 6:20:50 PM |
