Print at Oct 5, 2026, 2:23:21 PM
Posted by Gildaniel at Oct 16, 2019, 2:18:06 PM
Re: Two level with the same elevation: some rooms on upper level are transparent
I tested your case and this is my solution:
  • Select "Create walls" - double click on the grass,
  • delete grass,
  • select "Create rooms" - double click somewhere inside these new walls,
  • delete walls (if you don't need a fence)
  • cut and paste the house ( in order to select the house covered now by the new grass make level 0 unviewable or move aside the grass or select all and deselect the grass )
Thank you, it works! Good idea to redraw grass using walls!
