Print at Sep 29, 2026, 10:02:25 PM
Posted by Puybaret at Oct 28, 2019, 9:39:47 AM
Re: Two level with the same elevation: some rooms on upper level are transparent
I tried to fix the problem shown in the 3D view of your last image many times, and unfortunately there are still a few cases where it doesn't work. It's a problem about cutting the ground with rooms to avoid them to overlap the ground. Moving the corners of the rooms may resolve the issue.
