Sweet Home 3D Forum » List all forums » » Forum: Forum en français » » » Thread: [sweethome3d display via ssh -X Linux Debian] » » » » Post: Re: [sweethome3d display via ssh -X Linux Debian] |
Print at Sep 26, 2026, 3:12:00 AM |
| Posted by jeanmarcL at Nov 27, 2019, 2:44:19 PM |
Re: [sweethome3d display via ssh -X Linux Debian] Pour compléter les tests .... J'ai installé sweethome3d sur un portable arm64 (Pinebook) (avec 4 coeurs 64 bits), lequel est totalement opérationnel au niveau graphique pour une session locale. La distribution est une Debian 10.2 avec les composants suivants : jean-marc@pinebook:~$ dpkg -l |grep sweethome3d ii sweethome3d 6.1.2+dfsg-2 all Interior 2D design application with 3D preview ii sweethome3d-furniture 1.6.4-1 all Interior 2D design application with 3D preview (additional furniture) ii sweethome3d-furniture-editor 1.24-2 all Sweet Home 3D Furniture Library Editor ii sweethome3d-furniture-nonfree 1.6.2-2 all Interior 2D design application with 3D preview (additional non-free furniture) ii sweethome3d-textures-editor 1.6-2 all Sweet Home 3D Textures Library Editor jean-marc@pinebook:~$ uname -a Linux pinebook 5.3.9-sunxi64 #19.11.3 SMP Mon Nov 18 19:19:00 CET 2019 aarch64 GNU/Linux jean-marc@pinebook:~$ dpkg -l |grep java ii ca-certificates-java 20190405 all Common CA certificates (JKS keystore) ii java-common 0.71 all Base package for Java runtimes ii java-wrappers 0.3 all wrappers for java executables ii libactivation-java 1.2.0-2 all JavaBeans Activation Framework ii libapache-pom-java 18-1 all Maven metadata for all Apache Software projects ii libbatik-java 1.10-2 all xml.apache.org SVG Library ii libbcmail-java 1.60-1 all Bouncy Castle generators/processors for S/MIME and CMS ii libbcpkix-java 1.60-1 all Bouncy Castle Java API for PKIX, CMS, EAC, TSP, PKCS, OCSP, CMP, and CRMF ii libbcprov-java 1.60-1 all Bouncy Castle Java Cryptographic Service Provider ii libcommons-io-java 2.6-2 all Common useful IO related classes ii libcommons-logging-java 1.2-2 all common wrapper interface for several logging APIs ii libcommons-parent-java 43-1 all Maven metadata for Apache Commons project ii libfreehep-export-java 2.1.1-4 all FreeHEP Export and Save As Library ii libfreehep-graphics2d-java 2.1.1-6 all FreeHEP 2D Graphics Library ii libfreehep-graphicsio-java 2.1.1-5 all FreeHEP GraphicsIO Base Library ii libfreehep-graphicsio-svg-java 2.1.1-5 all FreeHEP Scalable Vector Graphics Driver ii libfreehep-graphicsio-tests-java 2.1.1+dfsg1-5 all FreeHEP GraphicsIO Test Library ii libfreehep-io-java 2.0.2-6 all FreeHEP I/O library ii libfreehep-swing-java 2.0.3-5 all FreeHEP swing extensions ii libfreehep-util-java 2.0.2-7 all FreeHEP utility library ii libfreehep-xml-java 2.1.2+dfsg1-5 all FreeHEP XML Library ii libitext-java 2.1.7-12 all Java Library to create and manipulate PDF on the fly ii libjanino-java 2.7.0-2 all runtime compiler for Java expressions - library ii libjas-plotter-java 2.2.6+dfsg1-4 all JAS(2) Plotter graphic library ii libjava3d-java 1.5.2+dfsg-16 all Java 3D API (java library) ii libjava3d-jni 1.5.2+dfsg-16 arm64 Java3D API (java jni library) ii libjavascriptcoregtk-4.0-18:arm64 2.26.2-1~deb10+1 arm64 JavaScript engine library from WebKitGTK ii libjaxen-java 1.1.6-4 all Java XPath engine ii libjaxp1.3-java 1.3.05-5 all Java XML parser and transformer APIs (DOM, SAX, JAXP, TrAX) ii libjdom1-java 1.1.3-2 all lightweight and fast library using XML ii libmail-java 1.6.2-1 all JavaMail API Reference Implementation ii libnb-org-openide-util-java 10.0-2 all Utility classes from the NetBeans Platform ii libnb-org-openide-util-lookup-java 10.0-2 all Utility lookup classes from the NetBeans Platform ii librhino-java 1.7.7.1-1 all Libraries for rhino Java Script Engine ii libsunflow-java 0.07.2.svn396+dfsg-17 all rendering system for photo-realistic image synthesis ii libtablelayout-java 20090826-4 all Java layout manager for creating user interfaces fast and easy ii libtagsoup-java 1.2.1+-1 all SAX-compliant parser for real-life HTML ii libvecmath-java 1.5.2-7 all javax.vecmath vector math package ii libxalan2-java 2.7.2-2 all XSL Transformations (XSLT) processor in Java ii libxerces2-java 2.12.0-1 all Validating XML parser for Java with DOM level 3 support ii libxml-commons-external-java 1.4.01-3 all XML Commons external code - DOM, SAX, and JAXP, etc ii libxml-commons-resolver1.1-java 1.2-9 all XML entity and URI resolver library ii libxmlgraphics-commons-java 2.3-1 all Reusable components used by Batik and FOP jean-marc@pinebook:~$ En lanceant sweethome3d dans la session courante, donc sans déport X11, le problème est identique concernant l'affichage, ce qui indique donc que le sujet n'est plus (ou pas pour le moment) sur le déport X11 via le ssh -X ou ssh -Y. Merci d'avance de votre aide Cordialement |
Current timezone is GMT Sep 26, 2026, 3:12:00 AM |
