Print at Oct 1, 2026, 1:05:40 AM
Posted by bdfd at Dec 4, 2019, 6:28:38 AM
Re: Two level with the same elevation: some rooms on upper level are transparent
Each house is always above the ground and it's one of the good practices.
For each construction you must have a base floor or screed and then just above and to simplify the first level.
If you look at all my recent projects (after 2016) the base is in gray and is between 10 and 15 cm thick.
The first level with the furniture therefore starts with a rise of 0.10 (or 0.15).
E.G. for a house with ONE floor :
wink
