Print at Oct 16, 2026, 12:44:45 AM
Posted by Puybaret at Dec 9, 2019, 8:32:47 PM
Re: import sketch up design
It's not a problem about how it will look like. Your house model at DAE / Collada format will be imported correctly in Sweet Home 3D.
It's a problem about ergonomics. Sweet Home 3D is designed to easily draw walls, place windows into walls and place furniture along walls on the floor of a room. As the notion of "wall" doesn't exist in an imported DAE file (and even in Sketchup as far as I know), you won't benefit of Sweet Home 3D features bound to walls and rooms with your imported model.
I would suggest you try to draw a simple house with Sweet Home 3D reading its user's guide or viewing some tutorials. Then try to import some existing houses from Trimble 3D Warehouse and you should quickly understand that arranging furniture in an imported house is far less handy than in a house which walls are drawn in Sweet Home 3D.
