Print at Sep 26, 2026, 6:58:44 AM
Posted by voldan at Dec 2, 2009, 7:21:36 PM
Re: A couple of questions
Thanks for the prompt reply.
I tried to use the round wall model, however it shows me a big square when in the 2D window (I am using the top view option for furniture in the plan). How do I correct that?
As for placing doors and windows on walls in an angle, what happened was that I changed the end point of the wall and then wanted to move the window to the correct place, problem was it wouldn't snap in, what I had to do was rotate it manually and position it manually without snapping. It is not always like this, most of the time it snaps correctly but sometimes (especially when the change in the wall is small and the door/window is near the edge) it just won't snap. So I thought maybe there is a way to manually snap it...
Thanks again.
