Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Cant Open Home Error » » » » Post: Re: Cant Open Home Error |
Print at Sep 28, 2026, 7:35:09 AM |
| Posted by Puybaret at Feb 5, 2020, 11:56:51 PM |
Re: Cant Open Home Error The file you shared contains only zeros i.e. no actual data. This error happens rarely and nobody found a way to reproduce it, so I can't fix it. Nevertheless, I had an idea to circumvent this issue in version 6.0 and wonder if you use this version or a more recent version. Is it the case? Any other hint which could help me understand how it happened? Anyway maybe you can use this tip to recover recently opened files: Look in the sub folders of C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D\work (where user is your login name) if you can find some files starting by open and suffixed by .sweethome3d. If there's any, it will contain the a copy of the document you recently opened. Copy the most recent file(s), change its extension to .sh3d and try to open it with Sweet Home 3D. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 7:35:09 AM |
