Print at Sep 28, 2026, 2:30:56 AM
Posted by YGYL at Feb 17, 2020, 4:28:00 AM
Re: Best to make Furniture Library Editor support .kmz format file~
For a file outside the 345345.kmz texture map file, I will give another example.
One person designed his own home with XXX, and used dozens of furniture in one color system. If this is a different kind of furniture that uses 2 texture files for external links, then if he wants to change a color system, it is very simple, just change the name of the folder on the hard disk. Load again and it's completely changed.
And the file of the whole way is very small.
Even if mobility is taken into consideration, it should also support this method or a built-in public mapping mechanism, instead of the current model where each model is a separate folder
