Print at Aug 28, 2026, 10:53:56 AM
Posted by digitaltrails at Feb 19, 2020, 6:35:58 PM
Re: SH3S installation as described for linux in website doesn't work
I had to perform a reinstall of Ubuntu so I could do a clean install using APT derek@Derek-R540:~$ sudo apt install sweethome3d
WRONG!!
The instruction from download page DON'T suggest such actions.
To solve Your problem You MUST FORGET REPOSITORY VERSION!
So:
1. sudo apt purge sweethome3d (to clean repository installation);
2. Follow STRICTLY the instructions from Download page:
-download->extract->run the SweetHome3D.sh file.
Simple as this!
It work on every linux and with every SH3D version from 3.0 ~ now.
If You steel need help we are here to help you hugs
You clearly ignore my first message and previous remarks in this forum.
You may have tested it on YOUR machine(s) the procedure DOES NOT result in a workable Sweethome 3D ON MY MACHINE.
As there are no error messages i cannot provide assistance as to why this is happening, starting Sweethome 3d result in a spinning pointer that stops no SH3Dscreen is opening.
SO unless you can provide me with terminal commands to execute that provide you diagnostics info I cannot further describe how SH3D fails to work
Further more all my previous work in SH3D will be lost
please check you comments
2. Follow STRICTLY the instructions from Download page: -download->extract->run the SweetHome3D.sh file.
Simple as this!
because there is no .SH file in the archive. the sweethoms3d file has no extension
You're not going to make much progress using the APT version from a GUI. No one here is likely to be familiar with how that was put together. If seeking (free) help here, it's better to work with what other people here are using. Even if many here are not using Ubuntu, one version of Linux is pretty much like any other in this instance.
The best path to follow is to persist with the instructions on the download page, but to initially run the resulting program in a terminal window so you can see the diagnostic output.
As you have also correctly determined the installation direction contains a script called SweetHome3D with no sh suffix (suffixes are optional/unneeded on linux, they are often omitted). The process of identifying and running the script might go something like:
ls -l SweetHome3D-6.2
total 188
-rw-r--r-- 1 michael michael 18007 Jul 11 2019 COPYING.TXT
drwxr-xr-x 6 michael michael 4096 Sep 12 10:37 jre8
drwxr-xr-x 3 michael michael 4096 Sep 12 10:37 lib
-rw-r--r-- 1 michael michael 901 Jul 11 2019 LICENSE.TXT
-rwxr-xr-x 1 michael michael 1130 Sep 12 10:41 SweetHome3D
-rwxr-xr-x 1 michael michael 904 Jul 11 2019 SweetHome3D-Java3D-1_5_2
-rw-r--r-- 1 michael michael 11873 Jul 11 2019 THIRDPARTY-LICENSE-BATIK.TXT
-rw-r--r-- 1 michael michael 8029 Jul 11 2019 THIRDPARTY-LICENSE-ITEXT.TXT
-rw-r--r-- 1 michael michael 22331 Jul 11 2019 THIRDPARTY-LICENSE-JAVA3D.TXT
-rw-r--r-- 1 michael michael 11519 Jul 11 2019 THIRDPARTY-LICENSE-JAVA.TXT
-rw-r--r-- 1 michael michael 18399 Jul 11 2019 THIRDPARTY-LICENSE-JEKSPARSER.TXT
-rw-r--r-- 1 michael michael 21381 Jul 11 2019 THIRDPARTY-LICENSE-JMF.HTML
-rw-r--r-- 1 michael michael 1680 Jul 11 2019 THIRDPARTY-LICENSE-SUNFLOW.TXT
-rw-r--r-- 1 michael michael 93 Jul 11 2019 THIRDPARTY-LICENSE-TANGO.TXT
-rw-r--r-- 1 michael michael 8031 Jul 11 2019 THIRDPARTY-LICENSE-VECTORGRAPHICS.TXT
michael@kosmos1  /usr/local/SweetHome3D  cd SweetHome3D-6.2
michael@kosmos1  /usr/local/SweetHome3D/SweetHome3D-6.2  ./SweetHome3D
If you wanted more details on what the script was doing:
michael@kosmos1  /usr/local/SweetHome3D/SweetHome3D-6.2  bash -x SweetHome3D
I also wonder if you might be using an nvidia card? I previously mentioned the useOffScreen3DView setting, which I believe is necessary if using a nvidia card with the proprietary driver.
