Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: SH3S installation as described for linux in website doesn't work » » » » Post: Re: SH3S installation as described for linux in website doesn't work |
Print at Aug 28, 2026, 10:53:36 AM |
| Posted by dorin at Feb 19, 2020, 8:52:06 PM |
Re: SH3S installation as described for linux in website doesn't work @DerekvG Let's take in the priority order: 0. Please accept my apologies. If I upset you, please excuse me.1. I want & I like to help You especially because You are a linux user. 2. You've right: -the SweetHome3D has no extension -some of the older versions I have will don't work on every machines. eg: --at work on intel cuore2duo not work some older version but at home on i3 2gen it work. 3. So let's try to fix'it: -in terminal: -- cd into folder where You uncompressed the 6.2 version -- ls -l (show us the out put) Should be like this (more or less): nea-dorin@debian:~/Sweet_Home_3D/SweetHome3D-6.2$ ls -l --Then execute in terminal: ./SweetHome3DSee what's happen & let us know. Theoretically must work but with computers You never be sure. 4. If previous attempt don't work, try a clean environment: --in Your home rename the .eteks folder to (let say) .eteks1 (that's to not loose furniture, texture and plugins but to start with a clean environment) --try again to run from SweetHome3D-6.2 directory: ./SweetHome3D--let us know what happen (if something happen) 5. For version from repository I can't help You while I don't use it from version 4 (or close) Let us know the results and provide more information if need. PS1 I've not understand what is with version 5.4 while now we are at 6.2? PS2 Don't worry about Your work; is steel there and You will be able to continue soon. Again Please accept my sincerely apologies! ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Aug 28, 2026, 10:53:36 AM |
