Print at Oct 2, 2026, 5:15:26 AM
Posted by fritzz at Feb 22, 2020, 4:02:35 PM
Re: How to provide floor plan parameters in a file
Thanks, great community here. And thanks for the guidance; here's what I've found:
Success opening the plain .xml, but only when 'image=' value matches the spec on the default catalog page you linked. Ex. "/com/eteks/sweethome3d/io/resources/textures/smallRedBricks.jpg"
Important to note: The leading slash has to be removed.
This makes it possible to read, modify and write XMLs using 'built-in' images, many thanks.
But still no joy using arbitrary images. Tried all kinds of things, from using fully-qualified filenames to playing with the ContentDigests and Home files -- just can't get the program to open the .xml when an arbitrary image is specified. Ex.:
Do as above w/ texture, save and close, extract Home.xml and file '0', rename '0' as arbtex.jpg (or anything), and manually edit the .xml to match. It will not open! Nor will it open using any other texture image. Please some more magic to make this work?
