Print at Oct 2, 2026, 3:13:02 AM
Posted by Puybaret at Feb 22, 2020, 5:41:21 PM
Re: How to provide floor plan parameters in a file
Great you could make it work partly!
Here's a SH3D file where I replaced the image "2" by "sea.jpg", used as a texture of a simple box.
Then I removed the obsolete catalogId attribute, removed ContentDigests and Home files, saved the SH3D file and it worked like expected. You're probably very close to a working solution.
Maybe we could get more information about the opening error, if you shared the error logs: just run the program from a Terminal window to get it (under Windows, add 2>log.txt after SweetHome3D.exe to send error logs to the file log.txt).
Attachment BoxWithManuallySetTexture.sh3d (14395 bytes) (Download count: 408) (Box with a manually set texture)
