Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Error in zipping furnitures to sh3f? » » » » Post: Error in zipping furnitures to sh3f? |
Print at Sep 26, 2026, 11:04:46 PM |
| Posted by gcalavaro at Mar 8, 2020, 4:01:22 PM |
Error in zipping furnitures to sh3f?Hi, What is the way to zip a folder with some furniture to create a .sh3f file, please? I created a folder with some furniture using as a template an existing sh3f file and modifying a couple of objects. When I zipped back the file I wanted to test it, by running it through the FurnitureLibraryEditor, but when it load this file it shows nothing (same results as the file was empty). To make a further test, I zipped the folder that I just created by unzipping an existing sh3f file that is working fine. When I run this zipped file, that should run fine as there was no change except unzipping and then zipping it back, FurnitureLibraryEditor again doesn't load anything and shows no furniture in that file. So what is the error I am making while zipping the folder to create the sh3f file? I tried by using the windows 10 Send To -> compressed folder function and by using 7-zip. In both cases I renamed the .zip file as .sh3f. In all cases the new file is showing nothing when opened by FurnitureLibraryEditor. Any help by the experts is very much appreciated. Thanks very much for your attention. Best regards, Giuseppe |
Current timezone is GMT Sep 26, 2026, 11:04:46 PM |
