Print at Oct 2, 2026, 1:16:43 PM
Posted by Xiste at Apr 9, 2020, 10:07:47 AM
Re: PhotoVideoRenderingDemo
Xiste, guess which one... tongue
Unfortunately I'm not owner of the same skills as you.
As Enko clearly points out, the lighting is done by him ( her?).
I wonder what are Enko's tricks for getting the light so natural.
As I am presently working on constructing and presenting my new studio, I'm trying to learn all I can about lighting.
My experience is that Yafaray gives very noisy results on light surfaces in dark areas, and I can't find any noise in Enko's renderings, which show many light surfaces in dark areas, f.i. in the first image where there is a perfect gradient leading into the corner at the center of the picture. This is an example of where Yafaray normally will produce noise, while Sunflow tends to produce banding. I see neither.
I wonder if Enko's perfect results depend more on the lighting, the render engine or the combination.
I also wonder what makes it so easy to say which render engine has been used on the different pictures.
Are there any particular signs I should look for?
Xiste
