Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 6.3 » » » » Post: Re: Sweet Home 3D 6.3 |
Print at Aug 9, 2026, 3:09:08 PM |
| Posted by YGYL at Apr 9, 2020, 4:01:46 PM |
Re: Sweet Home 3D 6.3- The 3D view proposes the new Select object item in its contextual menu to let you select the object under the cursor where you right clicked in the 3D view. When you press the Shift key, this menu item becomes Toggle selection and will toggle the selected state of the object under the cursor. Right clicking on a window pane will select the object behind the pane, so you'll be able to select a window in the 3D view only if you click on its frame. It is best to set it to double-click with the left mouse button to automatically select this object and jump to the floor plan window. Otherwise, many people will not know or use this function |
Current timezone is GMT Aug 9, 2026, 3:09:08 PM |
