Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Transparency on objects strange » » » » Post: Re: Transparency on objects strange |
Print at Oct 2, 2026, 1:41:12 PM |
| Posted by CarlosManuel64 at Apr 9, 2020, 8:32:37 PM |
Re: Transparency on objects strangeMerci bien. I was able to get what I want as you can see on the pictures. But have found something curious (for me). Because the texture is not "centered" I've made a Regular sculpture for the front and an horizontally inverted for the back. With new dimensions - now is a square picture to avoid been cuted on the top. Here goes the wall and the object at the right ***** https://ibb.co/P4H5ZgN I also found this: On the render by default, there is NO line on top of the object. With the YafaRay plug-in the line is there! And if you zoom the picture you will see that the YafaRay blurs the horizon line. ***** https://ibb.co/2dXW3qg The YafaRay produces a blured horizon and keeps the stange line on top of the object. But the image is more sharp. ***** https://ibb.co/hBh1R1r Let me know something about this, please. Anyway your help has solved my problem. Thank you so much. HAppy easter! Best regards |
Current timezone is GMT Oct 2, 2026, 1:41:12 PM |
