Print at Aug 9, 2026, 12:44:28 PM
Posted by Puybaret at Apr 13, 2020, 7:58:06 AM
Re: Sweet Home 3D 6.3
Sorry for the wrong links, I just fixed them.
@Gildaniel
I forgot to answer about your suggestion to be able to enter values when editing walls and rooms. That would be nice but at the opposite of creation time, modifications are done with a drag-and-drop. Authorizing to press <enter> and enter values while the mouse button is pressed (then released) would mix two modification behaviors which would make it too complicate to manage and understand by users. Or maybe I could allow the <enter> key while the mouse button is not pressed to allow the same modification with the keyboard as if the user would do a drag-and-drop... I will try, but if most of you here don’t see what I want to program after a first read, I’m not sure it’s a good idea either.
