Print at Oct 2, 2026, 10:04:44 PM
Posted by T3NZ3N at Apr 24, 2020, 7:13:01 PM
Re: Remove default libraries from Sweethome
You could either delete all the ones in the library you don't want, then add the ones you do want, then export with the plug in all the furniture you have to *sh3f file, and use that.
Or, you could rename the *sf3f file in the /data/furniture/ folder to a *.zip extension, the extract that, and select all the ones you wanted, combine them with the ones you have, then import them one by one
Or you could use the FLE and copy all of the individual Folder Files you unzipped into the same folder, together with all of your own furniture files for your market, and import all of the obj files into FLE and export your new *.sh3f library
