Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Texture Library Problems » » » » Post: Re: Texture Library Problems |
Print at Oct 3, 2026, 5:31:16 AM |
| Posted by T3NZ3N at Apr 25, 2020, 4:35:53 PM |
Re: Texture Library Problems well, those are factual occurrences, but I certainly understand the innate need to believe a certain way that makes you feel wonderful about everybody and everything all the time, and abhorring anything which gets in your way of such a utopian fairytale. Maybe it's better if you stop believing in malware as well, or just imagine it all comes from Nigeria or something. Cognitive Dissonance, in almost every instance, leads to some type of happiness. But thanks for letting me know, rather dramatically, that you aren't hanging around, and stomping off with some degree of sassy flair. Anyway, not talking to you anymore, but for the Internet at large, I do think I've narrowed it down to Java, and my install of Portable Java & Portable Java Launcher, and how that's working on my system without any Full JRE installed. I have the same set up with the Launcher, the CommonFiles Folder, and Java Portable in many different Portable Application Folders on my system for easy use and quick transfer to USB devices, so I can;t say removing the ones from this Portable Install would really make a difference, just that this program is the only one I've seen with the splash screen affected. |
Current timezone is GMT Oct 3, 2026, 5:31:16 AM |
