Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Using SH3D Portable's Java Files to Run the TLE & FLE » » » » Post: Re: Using SH3D Portable's Java Files to Run the TLE & FLE |
Print at Oct 5, 2026, 8:52:18 PM |
| Posted by Puybaret at Apr 25, 2020, 5:55:39 PM |
Re: Using SH3D Portable's Java Files to Run the TLE & FLE I'm not sure you can change the launch parameters if java is not installed. If you want to reuse the command you should rather store it in a .BAT file. And when you say "I may use javaw.exe", what does that mean? Simply replace java.exe by javaw.exe in the command I wrote.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 5, 2026, 8:52:18 PM |
