Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: 6.3 very greedy » » » » Post: Re: 6.3 very greedy |
Print at Sep 24, 2026, 2:16:03 PM |
| Posted by Puybaret at Apr 27, 2020, 8:31:59 AM |
Re: 6.3 very greedy Nothing changed on the rendering part. An explanation could come from an increase of the RAM used by Sweet Home 3D because you used 3D models with small repetitive parts that the program couldn’t correctly handle before. These models will generate a lot of faces to render and require more RAM. If the RAM use in the About dialog box looks close to the maximum set, you should consider increasing the maximum as explained in the FAQ. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 24, 2026, 2:16:03 PM |
