Print at Sep 23, 2026, 12:35:00 PM
Posted by Puybaret at May 8, 2020, 5:05:12 PM
Re: Export to HTML5 plug-in
I released the version 1.5 of Export to HTML5 plug-in to include features and fixes which appeared in Sweet Home 3D JS version 6.1 and 6.3.
It includes also a bug fix that prevents crashes under macOS 10.14+ when the plug-in is used with the sandboxed version distributed in the Mac App Store. In that environment, the only places where you'll be able to save the generated file are the /Users/user/Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data and /Users/user/Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data/Documents folders (where user is your login). You may create and use the subfolders of your choice in the folder Documents too, but it won't work anywhere else.
It's probably a limitation that Apple decided to add to protect users from plug-ins distributed outside of the Mac App Store and uncontrolled by its services.
